cc306 valve tune.
Old Sep 3, 2005 | 02:19 PM
weinerschizel's Avatar
cc306 valve tune.
Ok I'm tuning my valves on my LT1 w/ cc306. Here's the scoup. I use the "rotate the crank 45 degree" method to bring two cylinders TDC at a time. Is this cam a little different though? I seem to end up with one of the valves slightly open every time. What is the BEST method for tuning this cam. And please only experience people whom have tuned this cam.
Thanks much for your help!!
Old Sep 3, 2005 | 02:23 PM
Z95m6's Avatar
Re: cc306 valve tune.
By tuning this cam i'm assuming you mean setting the valve lash. If so i suggest you just turn the motor over a few times and each time check all the rockers and kind of just snug them down and lock them. Turn it over again and check them again as some always seem to loosen up. Then once you've turned the motor over a few times and none come loose then fire it up and adjust them while its running.
Old Sep 3, 2005 | 02:26 PM
joeSS97's Avatar
Do one cylinder at a time.Watch one valve open(spring compress) and adjust the other valve for that cylinder.Zero lash+1/4-1/2 turn.Repeat for the valve you watched compress.Repeat til all are done...It is a lot of turning of the crank,but they are done right.Hope you understand it,it isnt that difficult.
Old Sep 3, 2005 | 03:14 PM
Jameslt1TA's Avatar
Ya adjust them like said above and then do the running method...gets them much closer imo.
Old Sep 3, 2005 | 03:27 PM
30696bird's Avatar
I have the comp poly locks so I screwed them down by hand till they stopped......started the car and then adjusted them. Worked like a charm.
Old Sep 3, 2005 | 05:07 PM
I'm using poly locks also. Doesn't it make a horrible mess doing it with the car running?
Old Sep 3, 2005 | 05:09 PM
30696bird's Avatar
unbelievably...........I didn't get a drop out on the headers or anywhere else. If you don't rev the engine it won't get outta the heads.
Old Sep 3, 2005 | 05:11 PM
30696bird's Avatar
BTW, with poly locks it's right at 0 lash when you spin them down by hand and they stop. I got that off shoebox's site.
sleeperZ96BT
Sep 9, 2015 08:28 AM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
