cc306, stock heads, what rpm?
Old Feb 1, 2006 | 12:12 AM
Nick-LT1's Avatar
I have a 96 z28 with soon to be cc306 2800 stall a4 with stock heads what rpm should i take it up to. The car has 83,000 miles.
Old Feb 1, 2006 | 08:23 AM
zx1216's Avatar
Re: cc306, stock heads, what rpm?
Well i'm going to be shifting at about 6800 in my m6 with 195k miles on it, haha. I would say shift at 6500 but idk if that 2800 stall is going to be enough.
Old Feb 1, 2006 | 09:53 AM
jsetzer's Avatar
I had red line set at 6800 and was shifting between 6500-6800. Our stock tachs suck. Now I will have a shift light at least to help. I can check it with the pcm to see where I am actually shifting.
Landed me two spun rod bearings.
Old Feb 1, 2006 | 11:30 AM
96flame's Avatar
With stock heads I shift at 6200 rpms using a shift light because dash tach is out. The horsepower drops off by that point so no need going higher.
Old Feb 1, 2006 | 11:34 AM
jsetzer's Avatar
Looking at my graph, stock heads... it went flat from 5700-6300 (fuel issues) and fell off after that. Dyno and see where to shift.
Old Feb 1, 2006 | 02:58 PM
97Whitez28's Avatar
Well before I spun 2 rod bearings and a main bearing I was shifting at around 6500 with mine.......
I don't think these motors particularly like being spun that fast but o'well time to build the motor in the sig......
Old Feb 1, 2006 | 07:10 PM
qcworm's Avatar
these guys are right, stock haeds are going to quit "breathing" way before 65-6800 anyways. i would say drive it and do what feels right. the engine will tell you where it wants to be shifted if you just "feel" it. i know the wording dont make sense but i think most of you know what i mean,
Old Feb 1, 2006 | 09:30 PM
zx1216's Avatar
Well that is true that the stock heads are going to run out of steam around 6200 with that big of a cam. Although, when shifting to the next gear it is helpfull to rev it a bit higher in the gear before so it is farther up in the powerband after the shift. This may or may not get you a faster time but you just have to play around with it i guess and see what works.
Old Feb 2, 2006 | 01:17 AM
Nick-LT1's Avatar
so set it around 6200 rpm? Any one have a dyno graph of a stock headed cc306 car?
Old Feb 2, 2006 | 01:34 AM
Transamdriver's Avatar
My shift points were at 6250 and 6300 on stock heads. Rev it to 6700 now with the MSD set at 7000.
Old Feb 2, 2006 | 02:01 AM
cmking26's Avatar
I got a dyno graph send me ur email. Quits making power at 6200 so if I'm runing hard I shift at 6400 to fall back into power band. If your setting a limiter I would set it at 6600, that should be fine, and wont hurt if you bounce off it.
Old Feb 2, 2006 | 11:21 AM
96flame's Avatar
Cutout open and closed shown
Old Feb 2, 2006 | 11:52 AM
qcworm's Avatar
what other mods do you have. mine is bolt on only and i was expecting a little more than that. gunthers car was a cam and header car and he was putting down 399rwtq i dont remember the rwhp.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Killer94z
Jan 13, 2015 12:06 PM
Brian-94TA
Jul 31, 2002 02:52 PM
