cc306 normal or do i have a problem?
Old Mar 4, 2007 | 07:49 PM
kline454's Avatar
My 383 lt1 seems to surge at low rpms, under 2000rpms, is this normal with a cc306? car runs great, and you dont notice the surge unless your locked up in overdrive, or just hold the car at a steady rpm you can see the tach go up and down small amounts.
Old Mar 4, 2007 | 08:04 PM
kline454's Avatar
I also have a small ticking sound that i cant get ride of, my old motor made the same sound,after i put a cam in it, well i just built the 383 and it makes a small ticking sound like lose rocker arm,but isnt rockers, sounds like coming from the middle of the engine, someone told me its probibly the cam because it has a larger ramp rate you get some lifter noise?
Old Mar 4, 2007 | 08:36 PM
itzkwik's Avatar
i have a 355 w/ a 306 and it surges while driving at low rpm
Old Mar 4, 2007 | 08:50 PM
kline454's Avatar
ok thanks,
Old Mar 4, 2007 | 09:08 PM
zx1216's Avatar
my 306 has verry little surge on a stock heads/lower end lt1, your tune may be a bit off. The ticking may be a bad lifter.
Old Mar 4, 2007 | 11:39 PM
blackztpi's Avatar
its all in the tuning to a point.....but a 306 grind is definately not made for a 383 or low rpm. typically, the best numbers on a 306 grind come from smaller cube high rev engines. I drove a 383 lt1 306 cammed 6 speed, and then i drove a 306 cammed 350 lt1 with gtp stage 3 heads and you would not believe the difference. it was amazing and it seemed to be in it's comfort zone at all times. (automatic car with 3200 stall and 3.73's). I've seen them used in 383's a lot and they work fine, but there's a lot more to be found out of your 383 with a custom grind cam or a better matched shelf cam. After getting a couple, i swear on custom grinds...for the little extra cost, you cannot go wrong. contact bret bauer
Old Mar 5, 2007 | 01:07 AM
94/96ZsM6s's Avatar
get it tuned...i have a CC306 in my 396 no can surge at all...a freind of mine built a 383 lt1 with a 254/262duration, 106LSA, 626,626 lift and after a good tune there was no cam surge. before the car was tuned it surged all the time at low RPM's....
Old Mar 5, 2007 | 07:02 AM
kline454's Avatar
everything is new in the engine, new lifter rockers,pushrods,cam,pistons,crank,rods,ex.
Old Mar 5, 2007 | 07:04 AM
kline454's Avatar
as far as the tune goes its a mail order tune from mad Z, how should i go about getting it tuned? should i send him a email and see what he can do? or try to get it dyno tuned?
Old Mar 5, 2007 | 08:16 AM
MEAN LT1's Avatar
The best thing you could ever do is get it dyno tuned. But if your able to do that the your only other option is to scan it and then send who ever the file they can fix it.
Old Mar 5, 2007 | 10:51 AM
Critter's Avatar
with the higher cubes and tune i wouldn't see why it would be surging. 350 with mods in sig and no surge at all.
Old Mar 5, 2007 | 11:19 AM
jsetzer's Avatar
Do you have gears? I ask because why are you driving below 2k. EVERY cammed car no matter the make or year or size of the cam I have driven will buck way down low.
Old Mar 5, 2007 | 03:10 PM
kline454's Avatar
i have 3.73 gears, im under 2k when it locks up in overdrive, @ 45-50mph, but 55mph=2200rpm its good no bucking or surge,
Old Mar 5, 2007 | 03:30 PM
96LT1TX's Avatar
when people talk about driveability of cams, this is what they are reffering to mainly. The surge you are referring to is called cam surge, and can be tuned out but takes some definite effort to get completely rid of it.
Old Mar 5, 2007 | 05:36 PM
RunRiot's Avatar
Raise the TCC lockup by 5-10 MPH so it stays out of the surge area. Might want to raise the unlock too.
StansZ28
Feb 19, 2015 07:39 AM
Alex Barnes
Jan 24, 2015 10:21 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
Kix
Sep 8, 2002 06:30 PM
