cc306 or GM847
cc306 or GM847
I am getting a cam and haven't decided between these two. I am also getting hooker lt's, 52mm TB, ported heads, port matched intake, new springs and probably new lifters. I also have a 3800 stall and tunercat. In the future I will spray at the track only and probably no more than a 150 shot. I do not have any emmissions checks and only drive on the weekends. So which cam would you guys recommend? I want a very aggressive sounding and running cam. I will be buying it in the next week as I want to have this done by the end of next month.
Re: cc306 or GM847
Originally Posted by Camaro_Maniac63
Driveability won't be very nice with either one of those cams on a stock cube motor, unless you can tune the car very very well. Why not get a custom grind cam?
Brandon
Re: cc306 or GM847
Is this a stock cube motor, i take it? You'd like either of the cams, for what your wantin'..The GM cam will make some awesome power, just more top end, than the CC..I think..
As long as the tune is good, than drivablility wont be too bad..
Re: cc306 or GM847
Originally Posted by TransAmGT94
go with the cc306 that was my choice before i went with the custom grind
