CC306 Dowel Pin Length (optispark)
Anyone running the CC306 cam have to adjust the dowel pin length so that it's compatible with the optispark? I've read that some cams, if not adjusted, will shorten the life of the optispark. And since I've gone through my second optispark in the 20,000 miles, I'm wondering if that's what's causing them to go bad. Thanks in advance for any help on this.
Don't leave it up to chance. Always check the dowel length on any cam (custom or off the shelf) used in an LT1/LT4 engine.
The GMPP book states that the max length should be .620" from the face of the cam
Originally posted by AsianSensation
Even for a non venvented opti?
One last item, I understand the max OD to be .250" if you had to hammer it in and the tip mushroomed.
I understand that. That's why I posed this question... For those with a CC306 Cam, did you have to adjust the cam dowel pin length or not? Just want to know what experiences people had with this cam in regards to pin adjustments. Thanks!!
For 95+ optis DynaTecg advises dowel length max of .605" from face , max OD of .250" and max .375" from installed gear. I purchased one of their early production models before the 94- models were even available. I don't think you will disappointed with the DynaSpark.
