cc306 in daily driver
does anyone have this cam in a daily driver. i drive my car at least 20 miles per day, mostly city driving. i just wanted to talk to someone who does the same thing. i already have 4.10's so i dont think it will be that bad. but i would still like to talk to someone who actually does this.
thanks, david |
Re: cc306 in daily driver
For you David, I suggest a "stocker" cam in the 270-280 @ .050 for a daily driver. A set of 5.13 gears would complement this cam well. :D
Steve... |
I have it............with a good tune it has very little surge and drives great. I would never go back stock. (or smaller than cc306) :)
actually steve i was thinking about something in the 290 range with about .675 lift, the only thing that deterred me is that i was informed i would have to run synthetic blinker fluid and get a sealed muffler bearing.
seriously though i do need to talk to you about the whole cam/heads thing, i will probably either be pm'ing you later on or stop by thunder sometime... |
I had one in my LT1, wouldn't go any smaller than a 306. I Hope your heads are ported. 4.10's or 4.30's would be awesome for that cam. I had 3.73's on mine and felt my car was way under geared.
cc306 is fine for a daily driver, i have it in my ws6 and while its not my daily driver anymore, it was at one point and it was fine~gunter
Mine's not a daily driver, but the cam is fine for daily driving.
im putting one in a daily driver and was needing some info too. are 3.73 to high because i dont want to go any lower.
Planning on running it with my current 3:42s.. Ill let you know how it goes.
yea its fine save for maybe some stop and go traffic, but i wouldnt change it out. The idle definitely attracts a lot of attention. Other than that, i keep revs around 2k cruise in the first 4 gears, then can lug it down the highway at around 1700 or so at around 70mph
Yea let me know how the 3:42's work out...do these cams have some low end grunt as well as top? i want it to be able to rev up quik as possible.
that was my main worry..its a top end cam..but that might be a plus...i wont be using much power just to float around town so low end power isnt a huge concern..hell might spare me some gas mileage with the lower gears. :)
