cc306 correct dowel pin
Old Feb 5, 2007 | 08:06 PM
SS1156's Avatar
I was wondering how I can tell if I have the correct dowel pin in the cam for my car? I just bought the cam and saw a pic of another camshaft and the pin looks longer on the pic than the one on my cam. If it is the wrong one can I switch it out to the correct one?
Old Feb 5, 2007 | 08:12 PM
Bersaglieri's Avatar
Shoebox's website lists the proper length. Mine was fine out of the box, other have had to cut it down a swap them.
-Dustin-
Old Feb 5, 2007 | 08:19 PM
BoostinZ28's Avatar
Well comp cams send their cams out with a pin of .85 i believe and a 95+ lt1 corect pin length is .64 if im not mistaken i searched for it a week ago and found the answer so its on here but im pretty sure thats correct cause i just installed my cc306 in my 383.
Old Feb 5, 2007 | 08:32 PM
My CC306 pin was only .6XX.
-Dustin-
Old Feb 5, 2007 | 08:52 PM
BoostinZ28's Avatar
I think thats what mine came as i dont have a good micrometer but i half *** measured it with a tape measure and it was 9/16. whats that bout .52xx so it must be .6xxx lol
Old Feb 5, 2007 | 09:57 PM
SS Joe's Avatar
Be sure its not too long; a few years ago when doing a cam swap, I installed the cam without checking (it looked to be about right) and it destroyed the Opti in a matter of days.
Old Feb 6, 2007 | 01:42 AM
SS RRR's Avatar
Should be between .620 and .650
Old Feb 6, 2007 | 09:12 AM
cdb95z28's Avatar
I had to trim my Comp SR cam dowel pin also for my `95 LT1. It was too long from Comp. If I remember , I cut somewhere around .200" off.
Old Feb 6, 2007 | 11:01 AM
SS1156's Avatar
Thanks for the replies. The pin in my cam looks like the shorter one. I bought this cam used and I believe that it was in a 97 LT1. I will ck the length.
Old Feb 6, 2007 | 11:37 AM
buzz12586's Avatar
What is the easiest way to trim it?
Old Feb 6, 2007 | 01:11 PM
SS Joe's Avatar
I used a grinder to get it close, then a file.
Old Feb 6, 2007 | 01:42 PM
SS1156's Avatar
I was under the impression that the longer one was for the vented opti
Old Feb 6, 2007 | 02:45 PM
SS Joe's Avatar
Mine was the vented opti, but the dowel was still too long...I'd check any cam from now on, it was an expensive and aggravating mistake to make.
Old Feb 6, 2007 | 02:53 PM
OBE1 95Z28's Avatar
I ordered a comp cams cam for my 95 and it came with a pin approximately .3 which is probably the correct length for a non-vented opti. Therefore measure the pin length to make sure it's not too short too.
Old Feb 6, 2007 | 03:39 PM
In the pic above, the shorter pin is the correct length for a vented opti. The long pin will destroy it.
