Cc306 ?
Old Apr 6, 2006 | 09:25 PM
02LsGuN19's Avatar
Question Cc306 ?
I have went with a cc306 cam and i am using factory rockers & I need to know what length push rods I would need.
Thanks, Michael
Old Apr 6, 2006 | 09:27 PM
hotrod18_69's Avatar
Re: Cc306 ?
Stock one will be just fine.. 7.200
Old Apr 6, 2006 | 09:28 PM
Jazsun's Avatar
Re: Cc306 ?
sorry for the hijack, but why are you using factory rockers? Id think youd want to wait until you get 1.6 rockers and then buy new pushrods with the corect length, then buy pushrods for use w/ just the stock rockers.??
Old Apr 6, 2006 | 09:49 PM
02LsGuN19's Avatar
Re: Cc306 ?
tha are comp rockers not roller
Old Apr 6, 2006 | 09:50 PM
02LsGuN19's Avatar
Re: Cc306 ?
Old Apr 6, 2006 | 10:43 PM
HardcoreRM125's Avatar
Re: Cc306 ?
Stock lifters ?
Old Apr 6, 2006 | 10:49 PM
02LsGuN19's Avatar
Re: Cc306 ?
comp lifters
Old Apr 6, 2006 | 10:54 PM
Re: Cc306 ?
I dont know if they change the pushrod length or not. Use your stock one and turn the motor over by hand. Watch to see if the tip of the rocker arm pushes down on the CENTER of the valvestem. Actually, it will sweep across it. But if you have the correct length, it stays closest to the center. With the distance from each side being nearly identical. At full lift it should be on the intake side of the valve stem. At no lift, the fender side of the valve. And in mid lift areas it should be just about dead centered.
Old Apr 6, 2006 | 11:02 PM
02LsGuN19's Avatar
Re: Cc306 ?
ok thanks
Old Apr 6, 2006 | 11:08 PM
02LsGuN19's Avatar
Re: Cc306 ?
ok thanks
Old Apr 7, 2006 | 07:31 AM
Bersaglieri's Avatar
Re: Cc306 ?
The spring height is going to be an issue, and I'm hoping you changed those. Comp's website has a good section on valvetrain geometry, youll need a $10-15 pushrod length checker.
-Dustin-
Old Apr 7, 2006 | 04:15 PM
02LsGuN19's Avatar
Re: Cc306 ?
what length pushrod will i need for 1.6 roller rockers
Old Apr 7, 2006 | 11:05 PM
Re: Cc306 ?
As long as the heads have never been milled or the block decked, 7.2"
If these have been altered, you need to get a pushrod length checker, and find out exactly what you need.
mightymouse383
Jul 20, 2016 07:34 AM
Z Power
Sep 19, 2015 11:19 PM
Abdullah
Feb 6, 2003 06:23 PM
turbo_Z
Jan 31, 2003 09:45 PM
James3219
Jan 30, 2003 12:01 AM
