CC306 & 1.7 CC roller rockers
Old Nov 28, 2003 | 12:54 PM
96SilverRam's Avatar
Quick question. Does anyone know where to get the new CC 1.7 roller rockers for the LT1? Will the CC306 & 1.7 CC roller rockers work in a stock LT1, IE: lift issues ? If memory serves me right the CC306 with 1.6 RR produces .577 lift, so 1.7 RR produce .597 ???
Somebody put some logic to this
Old Nov 28, 2003 | 01:08 PM
jkipp84's Avatar
You can get them here.
Take the lift #'s you've got with 1.6's (544/576), divide each by 1.6, then multiply that result by 1.7 for each and that will give you the lift with 1.7's.
1.7's with that cam sounds like overkill to me, but whatever floats your boat. Just make sure you don't skimp on valve springs. You're gonna need some good ones.
Old Nov 28, 2003 | 01:13 PM
SAR2K's Avatar
If your still running stock pistons & valves you'll have MILES of piston to valve clearence. You'll run into retainer to valve guide clearance problems way before piston to valve.
Steve...
Old Nov 28, 2003 | 01:30 PM
formula383's Avatar
I too am considering switching to the 306 cam or adding 1.7 RR's to my HOT CAM setup but I don't think that I would do both if I were you.
The lift numbers would be 578/612
Old Nov 28, 2003 | 01:51 PM
Fastbird93's Avatar
Re: CC306 & 1.7 CC roller rockers
I've also heard that comp started to make an LT1 specific 1.7 rocker. Have yet to see it though. That link is for the Scorpion rockers, which I do have a set of. VERY nice piece of work.
Old Nov 28, 2003 | 01:52 PM
Kain's Avatar
You'd definatly need to get your head machined for bigger springs to allow for 600+ lift on the exhaust side. I don't think they make them for the stock spring diameter.
Old Nov 28, 2003 | 01:57 PM
jkipp84's Avatar
Ah, sorry about that link - Thunder has a 1.7 non/sa roller from Comp. in the LT1 valvetrain section.. PN: 63-1117-16
Old Nov 28, 2003 | 10:19 PM
WOW !
Thanks for all the great input so quick !
Old Dec 17, 2003 | 09:42 PM
2ZPOINT's Avatar
I wonder if you could run a 1.6 on the exhaust and and the 1.7s on the intake so you could keep it under .600 I have the cc306 and was wondering to buy 1.6s or 1.7s...
Old Dec 17, 2003 | 11:26 PM
I had wondered the same thing ? Anyone have any input into this idea. What part of Texas do you live ? I'm in Dallas.
Old Dec 18, 2003 | 06:25 AM
2ZPOINT's Avatar
Austin...just moved her maybe a year ago. The racing scene her sux compared to Houston.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
