cc306 = 1.6 what lift?
Old Feb 27, 2007 | 07:38 AM
  #16
kline454's Avatar
yeah i know what you mean,
Old Feb 27, 2007 | 07:40 AM
  #17
Z-RATED94's Avatar
Just trying to help out with what Iv'e read. I'm not trying to steer anyone in the wrong direction, or have them spend money they don't have to.
Old Feb 27, 2007 | 07:44 AM
  #18
kline454's Avatar
my ? was about them not being able to take the lift but my clearnce is there and they will work just fine from what summit has said, but yeah most people dont like useing SA rocker, becuase they can pop off,
Old Feb 27, 2007 | 07:45 AM
  #19
kline454's Avatar
but thanks for all the help everyone,
Old Feb 27, 2007 | 10:26 AM
  #20
1LESSZ28's Avatar
Originally Posted by mdacton
I don't think you quite understand, do you see how the rocker aligns? at the higher lift do you see how it has less side to side support? Take alook at everything and try to understand it....
I'm not trying to tell you anything bad but I have had one fly off at 6k plus and I was lucky
this is all I had
what lift and what camshaft did that happen with? you are very lucky-I have seen much worse.
Old Feb 27, 2007 | 01:39 PM
  #21
mdacton's Avatar
^^ 306
Old Feb 27, 2007 | 01:49 PM
  #22
kline454's Avatar
^what rocker arms?
Old Feb 27, 2007 | 02:02 PM
  #23
mdacton's Avatar
1.6 7/16" harland sharp -junk-
Old Feb 27, 2007 | 03:15 PM
  #24
kline454's Avatar
are you sure the rocker poped off? it looks like your useing hardened pushrods, and theres a lot of problems with them bending, there not good for high spring pressure, just thought i would give you something to think about.
Old Feb 27, 2007 | 03:28 PM
  #25
mdacton's Avatar
thanks for the advice but that was from 2001...just thought I would show
I also had rockers pop off with a hot cam, I personally do not like a self align rocker, they have there place but i don't like them
Old Feb 27, 2007 | 03:45 PM
  #26
rskrause's Avatar
Moderator
How do you figure hardened pushrods are a problem? That's what you must use with guideplates and non-SA rockers. There must literally be millions in use and that's what nearly every hi-po SBC and BBC uses.
Rich
Old Feb 27, 2007 | 05:01 PM
  #27
Ray@NitroDaves's Avatar
Rich
no problems here with hardened push rods...running .613 lift, comp pro-mags, and 7000RPM
Old Feb 27, 2007 | 05:03 PM
  #28
kline454's Avatar
Rich
do a sreach theres a thread on them its about 4-5 pages, the chromoly works alot better, my buddy bent like 3 pushrods before he went with chromoly now he has no problems,
Old Feb 27, 2007 | 05:05 PM
  #29
mdacton's Avatar
all chrome moly pushrods are hardened....
I think you mean el-cheapo hardened pushrods
Old Feb 27, 2007 | 05:06 PM
  #30
kline454's Avatar
yeah i never had a problem but many others have,
