CC305 Dyno Numbers
Old Jun 7, 2003 | 06:45 PM
97bowtie's Avatar
CC305 Dyno Numbers
I dynoed the car today. It rolled 335.5 rwhp and 346.68 rwtq. This was with the cut-out open. The A/F Ratio was around 12.8, with the car leaning out around13.2 from 5700 rpm around 6600. Not too shabby, but I was really hoping for 340. This is on 100% stock tuning...but given the a/f ratio was so good, there probably isn't much room for improvement - maybe a few degrees of timing would give a few hp. The graph is below.
http://www.public.asu.edu/~dbump/dyno.JPG
Old Jun 7, 2003 | 07:13 PM
Quickshotkimber's Avatar
Good #s. Have you done any headwork yet?
Old Jun 7, 2003 | 07:18 PM
got_hp?'s Avatar
his sig says stock heads, and considering the dyno numbers, im guessing theyre still stock.
good numbers tho for that cam.
Old Jun 7, 2003 | 07:34 PM
95 Silver TA's Avatar
Numbers look pretty good for stock tuning and stock heads. I could not see the graph to clearly, ar what rpms did the cam start to fall of at?
Thanks,
Claude
Old Jun 8, 2003 | 02:17 AM
97bowtie's Avatar
Thanks,
Claude
Thanks. The HP peaked around 5800 and power began to fall off around 6200 rpm.
Old Jun 8, 2003 | 02:25 AM
mastrdrver's Avatar
Nice #s for stock heads and programming.
I was suprised when I read this that you got that much for stock heads AND tunning. I thought you had atleast some tune on there. Do you have any new track times yet?
Old Jun 8, 2003 | 01:16 PM
Good to know....Thanks for the info,
Claude
Old Jun 9, 2003 | 06:24 AM
IDOXLR8's Avatar
Nice numbers
Old Jun 9, 2003 | 10:18 AM
americanmuscleman's Avatar
Originally posted by IDOXLR8
Nice numbers
Ditto!
Old Jun 9, 2003 | 11:24 AM
RealQuick's Avatar
Re: CC305 Dyno Numbers
Nice numbers. Thats actaully where I thought you were based on your mph at the track. Have you run with the new LT's at the track yet?
Old Jun 9, 2003 | 05:02 PM
Austin96Formula's Avatar
Red face
Man, i got the below numbers w/cc305 new valvetrain, long tubes, homemade cold air intake and i dont recall if the cutout was open or not.. also had some tuning. I think i need more tuning cause i'm running rich and I know that's not helping me at all.
Old Jun 10, 2003 | 06:49 AM
RealQuick's Avatar
You got an auto as well, but your numbers are low either way. When is the last time you gave it a tune up (pcv, fuel filter, plugs, etc.)?
Old Jun 10, 2003 | 08:37 AM
294rwhp is still about 350-360 flywheel hp through an auto assuming a 17 or 18% loss. 316rwtq works out to be about 375-380rwtq as well. Considering your still running stock heads, that sounds pretty reasonable to me.
I would also say change your fuel filter if you haven't in a while.
Old Jun 10, 2003 | 08:51 AM
T/A lt1's Avatar
294rwhp is low anyway you look at it. I know of 2 auto bolton cars making 290+rwhp stockheads and cams but good tuning. I think he needs a good dyno tune. JMO Later
Old Jun 10, 2003 | 10:54 AM
95_RipperZ's Avatar
294 is low. I made what is in the sig with those mods and crap 2.73s.
