CC pro mag RRs..7/16 or 3/8 studs needed ?
Old May 9, 2004 | 07:19 PM
RedHottG2's Avatar
Question CC pro mag RRs..7/16 or 3/8 studs needed ?
I am looking at buying a set of CC pro mag 1.6 RRs and the ones I found are the NSA 7/16 stud kind. I know CC also offers the 1.6 rockers in a 3/8 stud version. What is the diff. ? and wich do I need ? I plan on going pretty wild with my LT1 so I'm not sure wich kind I need.
Old May 9, 2004 | 07:31 PM
Josh-'04 GTO's Avatar
The stock studs are 3/8", but you should upgrade to ARP 7/16" studs anyway. They will flex a little less at higher rpm.
Old May 9, 2004 | 07:32 PM
SStrokerAce's Avatar
The 7/16 rockers are a much better way to go, you need a high quality ARP or Comp 7/16 rocker stud and the GM guideplates PN 14011051
This is a very good way to go for most HR cam setups.
Bret
Old May 9, 2004 | 07:33 PM
RedHottG2's Avatar
That's what I needed to know..thanks guys!!
Old Jul 23, 2004 | 02:14 AM
MTL_Z28's Avatar
Re: CC pro mag RRs..7/16 or 3/8 studs needed ?
Bret
Does anyone know if I can use the combination motorsports guideplates with arp 7/16" studs and pro magnum 1.6 rockers? Do I absolutely have to use the GM ones as stated above? I know that in some cases the guideplate can cause the hex of the stud to be too close to the rocker.
Do you think I will have problems if I don't buy the GM guideplates?
Old Jul 23, 2004 | 04:21 AM
97WS6SCharged's Avatar
I'm using Combination's guide plates in my TA with no problems.
Old Jul 23, 2004 | 04:25 AM
KenP's Avatar
I am using "Isky" adjustable guide plates. I had problems with the ARP guide plates not centering the rocker over the valve stem.
Parts Wanted
Mar 17, 2015 11:24 PM
alliance12364
Mar 6, 2015 04:39 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Catmaigne
Dec 25, 2014 12:16 PM
mjcent922
Jul 27, 2002 12:42 PM
