Catalytic Converter
Catalytic Converter
Well i went in to get my 94 z28 inspected today and failed it. They said it failed because of the cat. So looked underneath the car and who ever wielded the exhaust system did the worst job ive ever seen. Im goin spend a few hours reweilding it up and im also going to replace the cat. What are the inlet and outlet dimensions for the stock cat?
Hook it up to a scan tool and see what the BLMs are doing, if they are buried at 108 then O2s are the cause more than likely...a cat will have no effect on O2s (which determine what the BLM value will be) since the O2s are before the cat. A BLM value of 128 is perfect..any higher and its lean..lower and its rich.
NewsBot
Sep 14, 2015 02:02 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
