Cat with 2 bolt Flange on each end? Anyone?
Old Dec 12, 2003 | 02:56 PM
stereomandan's Avatar
I'm looking to find a high flow cat that has a two bolt flange on each end. Anyone know where I can find one at a good price?
My exhaust should end up like this:
Mac '94-'95 style headers, Y-pipe, cat, S-pipe, '96-'97 cat-back
Both ends of the cat need to be flanged with this setup. That way I can also replace it easily with a off road pipe or bullet muffler.
Does Carsound make one like this?
Thanks,
Dan
Old Dec 12, 2003 | 03:23 PM
Chevycobb's Avatar
i had a muffler shop weld a 3 bolt flange on the end of my y-pipe so I can bolt a cat on and off for emmissions testing...they messed up and angled the flange weird so when I went to bolt the cat or "test pipe" on it does match up right and causes an exhaust leak, and a really annoying noise...so just make sure they line up everything right.
Old Dec 12, 2003 | 04:44 PM
Thanks for the reply. I'm not an exhaust fitting expert, so this might be a dumb question.
Do muffler shops normally have the flanges that I would need to weld to the CAT or bullet Muffler?
Dan
Old Dec 12, 2003 | 05:56 PM
Chevycobb's Avatar
yeah they usually do, if not they can order some...most parts store don't carry them for some reason
Old Dec 12, 2003 | 07:49 PM
Z28ROC's Avatar
You'll want to go with a 3 bolt flange on the Y pipe side. a 2 bolt will usually leak like crazy. Then on the catback side, you want to use the ball and socket flange (stock setup). www.z28roc.cz28.com/Bullet.jpg
The only place that I know of that sells that part is RK sport. I'm sure someone else has them, I just don't know who. Also you could find someone with an old cat. and cut the ball off, and use that.
Summit sells 3 bolt flanges.
Old Dec 12, 2003 | 09:27 PM
How come it leaks at the Y-pipe with a 2 bolt flange and not at the cat-back side?
That bullet with the flanges is exactly what I was talking about, but I think the MAC headers only have a 2 bolt flange on the Y-pipe, at least it looks that way from the MAC header pictures here: http://www.macperformance.com/store/...Product_ID=457
Did you weld that yourself? If not, where did you have it done?
Dan
Old Dec 12, 2003 | 10:57 PM
Z28ROC's Avatar
Ok I see now what you're talking about.
If the macs really come like that on the Y pipe. Any exhaust shop will have that fitting. And yes it will work just fine. I thought you meant 2 bollt flat flange.
Yes I welded up the bullet in my garage.
Old Dec 12, 2003 | 11:06 PM
O.k. Thanks.
Let's say that I wanted to make a bullet ORP like you have. Mine would look the same except that the 3 bolt flange would need to be a female adaptor to accept the ball of the MAC Y-pipe?
Dan
Old Dec 13, 2003 | 12:25 AM
Z28ROC's Avatar
Yep, but you'll want to install the headers and y pipe first. So you will know exactly what fittings you need. And total lenghth of the orp.
maybe2fast
Mar 16, 2015 09:45 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
