Is a cast crank OK w/ n20?
Old Jan 25, 2003 | 04:07 PM
bad96firechikin's Avatar
Ok guys, I'm building up a little 355 ci LT1 for my '96 Trans Am. Putting in forged rods and pistons, however, I'm debating whether to leave the cast crank in place, or to upgrade to a hardened nodular iron crank for a little extra $$$. I know i can't afford a forged crank so far, b/c this buildup has costed me a great deal more than I had anticipated. I'm planning on putting a 125 or 150 shot of nitrous, and wanted to know if anyone had ever had a problem breaking the stock lt1 crank under these circumstances. Any advice is welcomed. Thanks,
Brandon
Old Jan 25, 2003 | 04:31 PM
funina91ss's Avatar
I run a 150 shot on a all stock bottem end.. with a 105k on it so my vote is the stock crank is fine...what C/R are you aiming for?
Old Jan 25, 2003 | 04:32 PM
Stock compression. Hearing what you run makes me feel much better about spraying a 150 shot on mine though.
Old Jan 25, 2003 | 04:36 PM
funina91ss's Avatar
you like them times?Just wait untill spring right now the car has drag springs getting liftbars for it and a 3000 stall fresh trans. and SFC..!sway bar too. then I will have to cut back on the N20 untill I get a cage...
Old Jan 25, 2003 | 05:10 PM
I do like those times! I'll be anxious to see how mine runs. How many times have you run the thing? I think that 11.96's on nitrous w/ a stock bottom end is plenty of proof that the crank is not the weak link in my motor. Thanks.
Old Jan 25, 2003 | 05:24 PM
funina91ss's Avatar
it has had 1 10lb bottle ran with 50-100shots(playing)and 1 10lb with a 150 2 8th mile passes and 2 1/4 mile passes ..only problems I have had since the N20 has been trans related.. hit the rev limitter from 1-2shift on the 11.96 pass..and slugish shift into 3rd.. but just waiting on the stall to get here ..(tue?)
Old Jan 25, 2003 | 06:50 PM
Anyone else had good luck spraying a 125 to 150 shot or bigger on a stock cast iron crank?
Old Jan 25, 2003 | 07:07 PM
funina91ss's Avatar
do a search in N20 tech there are few post now on a 355 setup...
Old Jan 25, 2003 | 07:14 PM
Derrick Redd's Avatar
Man I spray 150-175 on my stock bottom-end motor. How's 11.03 @ 125.53 mph spinning. Car should go easy 10.80's with traction. Don't sweat it. I know several people spraying 150+ on a stock bottom-end.
jbert55
Oct 31, 2015 03:52 PM
truthmatters
3rd Gen / L98 Engine Tech
Aug 19, 2015 04:09 PM
4586
Aug 18, 2015 07:08 AM
karpetcm
Aug 14, 2015 03:02 PM
Catmaigne
Jul 14, 2015 05:17 PM
