Car's running weak. Suggestions?
Old Aug 7, 2003 | 12:14 AM
Danno's Avatar
My car is really starting to irk me. It's a 93 A-4 car, mostly stock (CAI, TB foil, TB bypass, 160 stat, and a Jet stage2 chip), and it's running SLOW SLOW SLOW.
Symptoms: An almost imperceptable miss at idle, and a VERY strong gas smell from the pipes. Slow times at the track. I changed the plugs about 6k miles ago, and the miss was there even before that. It's not throwing any codes at all.
Track times, 2 different days, 75 degrees, almost no humidity both days, over probably 20 runs.
1/4 mile: CONSISTENT 14.4 at 96.5mph, 2.25 second short times.
BEST time was a 14.386 at 97 with 2.185 in the 60 foot.
I did get my opti wet once last winter, and the car ran like hell for about 3 days (horrible miss at 2200 RPM...bad enough to make it undrivable), but then magically "repaired itself", presumably when it dried out.
Things I'm looking at trying:
1. There's a small tear in my air intake elbow, but it looks like it's sealing anyway. I'll replace that with the LT-4 part, as they're cheap
2. Maybe a new coil/coil wire?
3. Pulling that JET chip out. I'm starting to think it's a piece of crap.
4. biting the bullet and going in after the opti.
Anyone think of anything I may be missing, or have any ideas at all? Help me out guys...I got spanked by a bone stock WRX on the strip, and that just stings.
The car's at about 45k miles or so, and has the original plug wires/coil/opti, and the original O2 sensor.
Danno
Red97LT1
9
Dec 17, 2014 06:13 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Brad122470
Aug 2, 2002 08:55 AM
Desolate_Flux
Jul 23, 2002 08:24 PM
