Carp, piece of starter stuck somewhere in the flywheel
Old May 19, 2005 | 05:41 PM
Beyonce Knowles's Avatar
Didn't think this was quite drivetrain material so...
I noticed my starter was cracked down the middle, so I pull it out, and what do I find but only half of the little semi-circle thing left on there. The other half has snapped off and its stuck somehwere around the flywheel, causeing that horrible grinding noise I complained about earlier. Is there any easy way to get it out? I don't think I can reach it through the starter hole.
Old May 19, 2005 | 05:44 PM
blown94's Avatar
Re: Carp, piece of starter stuck somewhere in the flywheel
Do you mean the nose of the starter that houses the pinion gear?
Old May 19, 2005 | 05:48 PM
jchevy's Avatar
Remove that black inspection plate, hopefully it will be sitting there in the bottom
Old May 19, 2005 | 06:24 PM
yep, that's it.
Hopefully I can get at it by removing that plate.
Any thoughts on what caused this?
Old May 19, 2005 | 07:06 PM
turbo_Z's Avatar
Originally Posted by Beyonce Knowles
yep, that's it.
Maybe there is something in the cylinder(s) preventing the piston from moving up. I know you said you somehow forgot to supply spark to 1 entire bank of the motor so it might be possible enough fuel accumulated in the cylinder to hyrdo-lock it and break the starter.
Old May 19, 2005 | 07:48 PM
silverz28's Avatar
That dosn't sound good at all. I think I had hydro lock at one time when I had water in my oil. Also, I had a small bolt from the back of the engine come out and wedge in the flexplate. I didn't notice it but saw it when I pulled the engine.
Old May 19, 2005 | 08:40 PM
Well, I it came right out after I moved the dust shield, no problem. I inspected the flywheel and didn't see any damage. With the new starter and the left side of the opti plugged in it started right up, no problems at all. Don't think anything is too wrong.
Maroz28maro
Jul 29, 2016 07:45 PM
Naanz
V6 Tech
Feb 14, 2016 11:11 AM
Jun 6, 2015 08:27 AM
Dec 4, 2014 11:56 AM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
