Carbon on piston sides after removing the head
Old Nov 16, 2007 | 11:50 AM
  #16
Wild1's Avatar
What kind of grease do you use? It has to be thin enough to dissolve with chemicals. A bearing grease may be too thick.
Old Nov 16, 2007 | 09:58 PM
  #17
JP95ZM6's Avatar
I do use bearing grease, whatever is handy. Not too much, I don't pack it in or anything. Just a layer. It's thick enough so it sticks to the walls when the poston goes down, so I can wipe most of it off. Then final rinse off with brake cleaner/vac. Again, I don't use too much, just enough to wet it. I don't think brake cleaner would be good in the oil. And I doubt it's sensor safe. Of course neither is an issue on 2-strokes.
HectorM52
Jul 30, 2017 11:46 AM
1963SS
Feb 6, 2015 10:05 AM
Chris Anderson
Jan 27, 2015 08:30 AM
squarehead
Nov 21, 2014 08:02 PM
