Car would not start and now will....
Old Apr 17, 2004 | 08:02 PM
cpformula's Avatar
I have a 93 Formula that has been converted to a 95 wiring harness. The car would not start this morning. It would turn over but acted like it got no spark or fuel. I checked the fuses, fuel pump and ignition coil. All were okay. I let the car sit for a few hours while contemplating about the optispark then tried to start the car. It started on the first try with no problems whatsoever.
Up until this time, the car was running fine. Never had problems starting. Now this happens....
Any ideas?
Old Apr 18, 2004 | 05:48 AM
slopokrodrigez's Avatar
The next time you have the problem, turn the key off as soon as it doesn't fire up. Then go KOEO for 2 seconds. Then key off. Then KOEO for 2 seconds again. Do this cycling about 3 times. Then try to start it like normal. If that makes her start up easier, chances are good that the check ball is bad in the fuel pump and it is allowing the fuel to run back toward the tank. If that is the problem, a fuel pressure gage can detect it when the engine is shut down by showing if the pressure drops fast after it is shut off.
If that KOEO trick doesn't help, pull the vac line off the fuel pressure regulator and see if it's wet. If it is wet, replace the regulator. If it's dry, put a fuel pressure gage on the fuel rail and monitor how fast the pressure drops when the engine is shut off. If it drops fast then you have a dripping fuel injector and it is flooding the intake after the engine is shut off.
Old Apr 18, 2004 | 11:59 AM
cpformula's Avatar
When the car wouldn't start, I used a fuel pressure guage and it was getting fuel. It also held pressure with KOEO. I didn't check the fuel pressure regulator.
Old Apr 18, 2004 | 02:15 PM
Dave88LX's Avatar
Mine did the same thing, turned out to be my fuel pump.
Do you hear it buzzing on?
Old Apr 19, 2004 | 04:17 PM
cpformula's Avatar
Yep. You could hear the fuel pump. It also had and held pressure at the fuel rail.
Old Apr 19, 2004 | 04:22 PM
95_LT1_6SPD's Avatar
if you dont mind me asking, what is KOEO?
Old Apr 19, 2004 | 05:35 PM
cpformula's Avatar
Key On Engine Off
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
teedoff59
Aug 8, 2002 01:36 AM
