car wont start. Think its tranny related.
Old Oct 17, 2009 | 02:02 PM
nodnarb481's Avatar
Has a new battery. When i try to start the car you can hear the starter click but nothing happens. I think it might have something to do with the car not thinking its in park. Does this make any sense? Like maybe the linkage is loose underneath the car or something? Cause i dont have any other ideas.
thanks
Old Oct 17, 2009 | 02:10 PM
SmokeyBlaZe's Avatar
Did you tighten the battery connections all the way? I doubt the tranny has anything to do with the car turning over..
Old Oct 17, 2009 | 04:52 PM
Spartan7's Avatar
The linkage could be off the tranny and it would still start as long as the shifter is in PARK or NEUTRAL. It's the switch on the shifter that tells the PCM that.
I agree with the above post, look at your battery cables again.
Old Oct 17, 2009 | 05:44 PM
nodnarb481's Avatar
alright ill check the cables again. My haynes manual also says that the problem could lie with the main solenoid contacts or the starter motor itself. has anyone had experience with this and could tell me what their symptoms were like?
its rainy and freezing so theres little work i can do on the car so im just gathering information until the weather lets up.
Old Oct 17, 2009 | 07:35 PM
slo bird95's Avatar
i agree with starter. Pretty easy change out.
Old Oct 18, 2009 | 01:44 AM
joshmullins8's Avatar
About 2 months ago I rebuilt my motor and when I went to reassemble it I accidently put a ground wire that was suppose to ground on my tranny, I put it on my starter and every time I would go to start the car it would click but then just ground the starter out right away to where there starter wouldnt kick out the bendix, it took me weeks to finally realize it. Thats what it sounds like to me, have you messed with your starter recently?
Old Oct 18, 2009 | 09:41 AM
nodnarb481's Avatar
havent touched the starter in a lonng time. Im willing to bet theres some wiring issues somewhere. I just gotta get out there and snoop around. i know the battery terminals are tight at least
Old Oct 18, 2009 | 10:40 PM
nodnarb481's Avatar
tried to figure it out today when i went to replace my o2 sensor..started up first try. so it remains a mystery.
Old Oct 19, 2009 | 05:31 AM
Was it the passenger side O2? Starter wire, ground, O2 sensor wire and knock sensor wire are all in the same harness bundle.
nballisru
Dec 14, 2014 05:01 PM
mattszm6
Dec 14, 2014 07:09 AM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
Dave19yz28
Jan 26, 2003 01:45 PM
