Car wont start... SECURITY light.
Old Mar 6, 2004 | 05:49 AM
S.J.S.'s Avatar
Hey guys...... last night I was in my car and when I stoped I turned the car off. When I went to restart it the ignition turned but nothing else. All the power was on and everything was working but there was the "security Light" on above the odometer. I played with the doors, and gears for awhile and the light went off. As soon s it went off the car started like normal. Has anyone had this problem???
Thanks.
Old Mar 6, 2004 | 07:44 AM
n2oCamaro's Avatar
Yeah, like 3 times. I don't know what causes it, but I have to pull a fuse (PCM or ignition, don't remember which) to get it to reset.
Old Mar 6, 2004 | 08:23 AM
jchevy's Avatar
The little chip in your key is going bad or dirty.
Old Mar 9, 2004 | 11:17 PM
S.J.S.'s Avatar
seriously??? no kidding. Anyone else had this problem??
Old Mar 9, 2004 | 11:20 PM
NewbieWar's Avatar
i called for help once the guy said use ur keyless entry remote, and lock and unlock the doors a few times... but that wasnt my problem so i couldnt tell u if it works
Old Mar 9, 2004 | 11:34 PM
95Zdroptop's Avatar
Clean the chip in you key with rubbing alcohol. Just a little dirty.
Old Mar 10, 2004 | 12:01 AM
TraceZ's Avatar
You are dealing with the VATS. (vehicle anti theft system)
The VATS module verifies the value of the pellet on your key. If the value is not correct, the car will not crank.
If the key pellet is dirty, or the contacts inside the lock cylinder are worn it will fail and show the problem you saw.
Try to clean the key, then try a different key. If that does not work you may need to replace the lock cylinder.
Old Mar 10, 2004 | 12:03 AM
S.J.S.'s Avatar
thanks for the help guys. the only prob is that, it only does it every once in awhile so I can't tell if I fixed the problem for awhile.
BUt thanks for the info. Cleaned it already.
Old Mar 10, 2004 | 04:50 PM
marshall93z's Avatar
i had to replace my cylinder...
Old Mar 10, 2004 | 04:55 PM
DubbyZ28Camaro's Avatar
Yep that is correct. The VATS detects a certain resistance coming from the lock cylinder/key assembly. If that resistance is not correct due to dirt on the resistor pellet, then the vehicle will not start. Someone also mentioned a lock cylinder problem which could also be the case as they go bad very often in these vehicles.
Hope this helps.
Old Mar 10, 2004 | 05:05 PM
Stormman's Avatar
Usually cleaning it does this trick. It happened to me.
if cleaning doesn't help have a new key cut.
Old Mar 10, 2004 | 05:29 PM
VegasZ's Avatar
Here is a little trick. When you go to start the car, put the key in, then wait a half second before turning. This way the computer has time to read the key. Ive dealt with this issue too, but not since doing this.
Old Mar 10, 2004 | 05:52 PM
97RedT/AWS-6's Avatar
My key had worn down so much I had to toss it and use my spare. Check the resistor on your key for wear. Eventually mine stopped contacting the ignition.
cmdeshon
Dec 27, 2014 10:06 AM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
