Car won't start/just completed FAST install
Old Apr 18, 2007 | 08:57 PM
cn383's Avatar
i just completed my FAST system installation today and car will not start. the starter will not do anything,no click,nothing. yesterday it turned over fine. the only thing i did today is wire my fuel pump to my FAST system.i checked all fuses and the purple wire from 4 pin connector on the passenger kick panel is not recieving any signal to the starter.you can hear a relay clicking under the dash when the key is switched on. i checked the clutch switch and it seemed to be fine.does the fuel pump wiring control any of the start functions?any help would be appreciated
Old Apr 18, 2007 | 09:36 PM
Kevin Blown 95 TA's Avatar
Might be VATS not sending the signal to the PCM. Did you scan for a trouble code? See of there is a code 46 stored.
Old Apr 18, 2007 | 09:40 PM
cn383's Avatar
the original pcm has been removed.the FAST system controls my engine functions
Old Apr 19, 2007 | 02:46 AM
ZBLKHELLRZR's Avatar
Are you using the original FAST or the XFI? You may want to try the GN forums as there is a big group of guys there w/ there own dedicated section for SA units.
http://www.turbobuick.com/forums/
Old Apr 19, 2007 | 06:13 AM
Dave89IROC's Avatar
you said it's not cranking?
Old Apr 19, 2007 | 09:09 AM
WS Sick's Avatar
Edit, I went back and loked at the schematic.... and yes the big purple wire does go through the VATS system.
Old Apr 19, 2007 | 04:22 PM
Dave89IROC's Avatar
yeah, it's easy enough to rewire the theft deterrant relay though
wait a few and I will tell you how
Old Apr 19, 2007 | 04:34 PM
Dave89IROC's Avatar
ok, here you go, you just need to ground the yellow/black stripe wire thay comes off the TDR
Old Apr 19, 2007 | 09:27 PM
cn383's Avatar
thanks,i ran a jumper wire from the yellow w/black stripe wire to a ground and it worked perfect. thanks
hotrodyou1
Dec 20, 2014 10:05 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
sc93
Jul 26, 2002 02:02 PM
Jon657
Jul 19, 2002 07:51 PM
