car wont start after running low on gas
Old Jan 25, 2004 | 01:35 PM
chamealeondroptopZ's Avatar
These damn gas gauges in thes cars I just got a 95 Z 3 weeks ago,and the car has been running perfect.The needle was near the E but not on it,and I was less then 20ft from a gas staion and the car stalled.(I've ran ran both my T/A's ive had before several times on fumes)anyway I pushed it in,put gas and F.I> cleaner in it and it still wouldn't start I then had it towed home.I took out the fuel filter and there is no gas coming out of the line when I crank it. Does it Sound like its deffinattely the fuel pump,before I buy one and hack into my trunk?Thanks.
Old Jan 25, 2004 | 01:41 PM
94TEALz's Avatar
I would say its 99.9% the fuel pump
Old Jan 25, 2004 | 01:42 PM
white97z/28's Avatar
I know what you mean with the camaro gas guages, all of the 4th gens ive been in and owned are messed up. My car acted similar to yours when i ran out of gas but mine didnt run completely out. When i cranked it would idle really rough and jump up to 1500 then down to 500. I went and got $4 worth of gas and it cured it. Sounds like your pump quit though.
Old Jan 25, 2004 | 01:52 PM
flyinZ's Avatar
Ya, sounds like u might have burned it up..Just replace it and you'll be back to normal.
Old Jan 25, 2004 | 01:53 PM
NewbieWar's Avatar
yea my dad always told my mom that running outa gas will kill the pump, but in our old f350 it had 2 tanks and everytime she'd wait till it was turning over w/o enough gas...
heh she also push started an automatic like that going down the grapevine at 75 w/ a load the engine shut off and started back up a few seconds later
Old Jan 25, 2004 | 02:09 PM
Hyperspeed97z28's Avatar
Check ebay for 94-97 fuel pumps under the search "lt1"
you can get one for about 80 to the door
Old Jan 27, 2004 | 06:35 PM
These cars don't have a fuel pump fuse right?My owners manual doesnt show one,but a few people have said its under the dash,but,I did a little shoppin around.(I'm leery about buying a used one fron ebay)Summit has the Granatelli (is that the walbro?) one for $125 plus about $20 for shipping within 2 days.Anyone have that kit and is there any problems installing it?Or should I just get a new Delco one,which I found for $154 from a distributor.I dont plan on souping this car up much so I dont really care about the xtra lph.what should I do?
blac94Z
Nov 28, 2014 01:53 PM
blac94Z
Nov 24, 2014 07:12 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
Dave19yz28
Jan 26, 2003 01:45 PM
MJ_Z28
Aug 7, 2002 07:15 PM
