Car wont Start.
Old Oct 15, 2006 | 12:15 PM
Ok4thGen's Avatar
Car wont Start.
when the key is turned everything lights up but the car wont even attempt to crank over, the starter wont click nothing.
car is a 93 what is some of the things i should check?
car ran perfect all up until this point.
Old Oct 15, 2006 | 01:08 PM
CamaroSS30thAnn's Avatar
Re: Car wont Start.
take the starter off and have it checked at an autozone or auto place in ur area
usually if its a starter problem , no click is dead starter, clicking with no crank is a low battery
Old Oct 15, 2006 | 02:32 PM
Eric_96Z's Avatar
Re: Car wont Start.
Same thing happened to me, the problem was the neutral safety switch.
Old Oct 15, 2006 | 03:44 PM
roguedriver's Avatar
Re: Car wont Start.
Have you tried to jump it yet? I've had no clicking and no anything with a weak battery. If it starts on a jump though (assuming your terminals aren't loaded with acid crud), then battery for sure, and if that, then make sure your altenator didn't take out the battery first.
Ken R.
Old Oct 16, 2006 | 06:40 PM
Ok4thGen's Avatar
Re: Car wont Start.
Ken R.
Problem was the VATS System i did the bypass and now everything is fine.
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
