car wont start
Old Mar 29, 2006 | 08:13 PM
A2GrLT1's Avatar
Unhappy car wont start
car ran perfectly before i put it away for the winter. i took off my roller rockers thinking that i was going to go 1.6 but never got the chance. i go back maybe january put them back on.. f' that up by not knowing how to set zero lash, and f' up some rods. now i have got new rods, and have figured out how to set zero lash, go back today and try to start her... no luck. it will turn over fine and will come close to starting, but wont start. i have officially run out of ideas and cannot find anything on the board that relates directly to my problem. any help would be greatly appreciated. also wut i did for setting zero lash is tighten down finger tight and try to start is this correct (i dont wanna f' up again).
Old Mar 30, 2006 | 05:19 AM
Guest47904's Avatar
Guest
Re: car wont start
Did you make sure the valve you were working on was on the base circle?
Old Mar 30, 2006 | 07:21 AM
A2GrLT1's Avatar
Re: car wont start
if you mean by putting it at tdc then no. i am very new to the internals of the engine so if you could explain that would help a lot.
Old Mar 30, 2006 | 07:47 PM
93transam1234's Avatar
Re: car wont start
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
try doing it that way
Old Mar 30, 2006 | 08:22 PM
A2GrLT1's Avatar
Re: car wont start
ya i figured it out and shes back in the game thanks to shoebox
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
