Car won't start
Old Aug 17, 2005 | 06:45 PM
SBHoney's Avatar
Unhappy Car won't start
I am having a problem with my car. It is 94 Z28 and it wont start. I was driving down the road about three weeks ago and the car just died. I replaced the opti with a brand new one from a dealer and the car still wouldn't start. Turned out to be the ignition fuse was blown. Replaced it and the car ran for about two days. The problem is that I was once again driving down the road and the car died. This time I checked the fuses first but they seem to be fine. The car cranks but does not start. Fuel pressure is good. Anyone know what could be going on. One thing I did do both times this happened is I stomped on the car a little to pass someone but I am not sure if this had anything to do with it.
Old Aug 17, 2005 | 09:24 PM
ttop1986's Avatar
Re: Car won't start
Now i know you said your fuel pressure is fine, but mine did something like that before when my fuel pump went out. It would drive ok here and there, then it would randomly die, and have trouble starting. i got it started a couple times before it finally **** the bed. I guess that means fuel pressure was ok at times... but then would crap out, then it would b ok, then crap out. So id look into your fuel pump some more.
i was on the highway and it randomly died. I pulled over sat a couple minutes and it started back up. i started driving again, about 2 miles down it died again. that time was for good.
Britbilly
Jan 7, 2015 08:49 PM
Dec 4, 2014 11:56 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
lbrowne
Nov 13, 2011 04:25 PM
