Car won't fire...
Old Mar 5, 2007 | 08:59 PM
jball's Avatar
Car won't fire...
Hey if you guys could help me out...
Drove the car...ran fine...shut it off for a min to run in the store...after that it wouldn't fire again...for a few weeks now it hasn't fired. What would cause it just to die...no sputtering, no mis firing, just died.
Old Mar 5, 2007 | 09:07 PM
Dave89IROC's Avatar
could be any number of things
you need to check for spark, fuel pressure, ect.
Old Mar 5, 2007 | 09:11 PM
jball's Avatar
I know its the spark...just what part in the ignition would make it just die and not restart...if it was the optispark it would sputter and run rough before it died wouldn't it?
Old Mar 5, 2007 | 09:20 PM
OBE1 95Z28's Avatar
And you know it's spark how It's common for the check valve in the fuel pump to get stuck open making the car not want to start or even the fuel pump dying altogether. Save yourself some money, don't throw parts at it, diagnose the problem. Check for a hot spark and proper fuel pressure.
Old Mar 5, 2007 | 09:22 PM
Dave89IROC's Avatar
ICM, Coil, Opti, Coil wire, power feed to coil/ICM/Opti, ect.
look here
http://shbox.com/1/4th_gen_tech1.html
and you will find info on diagnosis
specifically, here
http://shbox.com/1/4th_gen_tech2.html#opti_test
Britbilly
Jan 7, 2015 08:49 PM
CARiD
Dec 26, 2014 04:20 AM
Dec 4, 2014 11:56 AM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
