The trans on 94 up F-bodys is electroinic shift, there is no TV cable, shifts are controlled by the PCM
is you check engine/service engine soon light on?
ok.......so since the car wont downshift? what is keepin it from downshifting??is there any kinda of electronic shift switch or sensor?? can anyone helP?thanx
could be your TPS. I've had this problem twice one time it was the TPS and other time was IAC valve. Is your engine idling fast?
Makaveli, I've had to change TPS twice and both times they were bad the engine idled fast and the transmission wouldn't downshift. Same way with the IAC valve. I would suggest getting another TPS. And also try cleaning IAC valve.
