car vibrates over 60 mph?
Old Jul 10, 2008 | 01:57 PM
CGrant's Avatar
Ok, this is just too weird?
If i drive the car under 60 mph it is fine, if i take it past 60 mph it starts vibrating the entire car?
I am planning on checking the tires and rims this weekend but could it be anything else?
Thanks!
CG
Old Jul 10, 2008 | 02:00 PM
ShownomercyZ28's Avatar
Driveshaft.
Old Jul 10, 2008 | 03:43 PM
Dadic 78's Avatar
tie-rods, balljoints, etc... Is it coming from the front end, or the rear?
If you can isolate the vibration location, you'd be in a better position to get some feedback from other forum members.
Old Jul 10, 2008 | 04:32 PM
BUBBA's Avatar
Is the first time you noticed it? Some drive shaft use to do that and many switched over to LS1 shafts or other aluminum shafts. However if it never has done it before, it may be your tires.JMHO
Old Jul 10, 2008 | 04:35 PM
whammer33024's Avatar
i'd say you're out of alignment
Old Jul 10, 2008 | 10:17 PM
SS RRR's Avatar
would cause vibration?
Another vote for driveshaft or bent wheel.
Old Jul 11, 2008 | 01:11 PM
CGrant's Avatar
As far as i can tell its coming from the back?
I was always told that if you feel it in the steering wheel its the front end and if you feel it in the seat of your pants its the body/back end but i am not sure if that is true?
forgot too mention...it just started, it did not do this before.
Old Jul 11, 2008 | 03:35 PM
CheshireCat's Avatar
Sounds like it isn't the front end.
Could be
Transmission
Driveshaft
Rear Axle
Rear wheels/Tires/ballance
Rotate your rear tires to the front and see if that changes where you feel the vibration.
Old Jul 12, 2008 | 10:13 PM
gpss97's Avatar
is it mainly when you accelerate or decel? i had a problem like that but i got hit at a higher mph, and foun dout the pinion nut backed off and my yoke was loose and vibrated like crazy. it was there a lil when accelerating above 70, but it was the worst on decel.
Old Jul 12, 2008 | 11:07 PM
WS6T3RROR's Avatar
Could be a whole host of things:
Tires out of balance
Bent wheels
Driveshaft
U-joints
Pinion angle
Trans Tailshaft bushing
Pinion bearing
Torn trans mount
Worn out torque arm bushing
Worn front suspension bushings ball joints etc
The list gets a lot longer, but its usually one of those. If its been more than about 20k since the tires were balanced and rotated I would start there.
mattszm6
Dec 14, 2014 07:09 AM
CaRParts102
Dec 6, 2014 08:45 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
LumpyCamZ28
Aug 13, 2002 09:16 AM
