Car turns over and turns over but doesnt start
Old Feb 2, 2007 | 02:37 PM
  #16
BUBBA's Avatar
You don't need an adjustabel FPR---but it won't hurt to get a FP guage which includes the gage, a hose, and an angled connection that will easily fit the valve (take a look at it on firewall, pass side w/ the little cap on it so you can get the right fitting.) FP should read 43-46 with vac hose off (simulating WOT). Should read about 8 less when hose connected.
Have you checked to make sure your Idle Air Control IAC is working? Doesn't hurt to clean the TB either---just in case your problem is that you are not getting sufficient air when you first start the engine without foot on pedal.
May be a problem of air rather than fuel.JMHO
Old Feb 2, 2007 | 02:55 PM
  #17
BUBBA's Avatar
BTW: even though you say that the PCM is not the culprit, it would be wise to borrow one from a friend, or buy a cheapie stocker and install it to see if it makes a difference. The idea is to eliminate possible culprits one at a time until you have the problem isolated---you can screw around with the thing forever, but if it is the PCM and you don't eliminate it, you are IMHO subjecting yourself to unwarranted stress.
Old Feb 2, 2007 | 07:30 PM
  #18
DSIM's Avatar
Originally Posted by aaron_depue
I thougt about it but I turns fine. Im getting checked out at a diagnostic shop monday assuming that I can get it started. Thats for the info.
i didnt know that that was how that system worked.
I know it sounds cooky, but mine turned over fine as well. When they go bad, they just need a little extra help (fuel) to get things rolling. When I did mine, it would crank for 10-15 seconds, and it would sound fine. Put the new one in, and it would start up in 1-3 seconds.
Old Feb 7, 2007 | 06:14 PM
  #19
BrandonKeith's Avatar
Any resolution on your problem yet? Kind of wondering what the culprit is. Hope you get it figured out.
Old Feb 13, 2007 | 10:29 AM
  #20
aaron_depue's Avatar
Yeah it was my MSD 6A module. He took it out and plugged my OE ignition back in and worked but it had been flooded once pretty bad and it wet fouled theplugs so I had him install a new set (lucky guy). All is fine and dandy now
jj71787
Dec 30, 2014 02:15 PM
A's 91 Z28
Dec 7, 2014 12:09 PM
NewsBot
Dec 3, 2014 12:30 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
