car temp. is always high
Old Jun 20, 2004 | 04:10 PM
95...Z28's Avatar
hi every one........after long time...
I have a serious problem in the temperature.....
last year I had install the hypertech powerstat and also a fan switch... enveything was under control... without AC the fans work automatically.... and the temp. drop down the fan stop......
but this year.....the temp. won't like to drop down.... and the fans keep working all the way...... .. I replaced the thermostat again>>>but nothing happens... do I have to change the water pump...or to check the head gaskets.......
please help.................
aslo with AC the temp. goes near the top
Old Jun 20, 2004 | 04:48 PM
Fastbird93's Avatar
I would say don't use the A/C but being in Bahrian it's kind of a necessity huh??
If you have the ability, put the car on a scanner to see what the car is actually running at, as the stock gauge isn't the most accurate.
You could try and change the coolant temp sending unit for the in dash gauge, which is located on the driver side head. Those are known to fail from time to time, and would cause an erroneous reading.
Is the cars performance affected at all when the temp is showing so hot????
As for the water pump, take a look at it and see if it's leaking from the weep hole. If it is then you most likely need a new one.
Old Jun 20, 2004 | 05:04 PM
95...Z28's Avatar
thanks Fastbird93 alot for ur reply>>>>>>>>>>>
I'll change that sensor........then I'll let you know.....
97SSdude
Dec 31, 2014 07:43 PM
brentbrowning01
Dec 16, 2014 06:35 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
