Car taking longer to start
Old Aug 11, 2011 | 08:43 PM
  #16
92rslt1's Avatar
Re: Car taking longer to start
Originally Posted by Injuneer
Check the fuel pressure. Your symptoms are typical of the fuel pressure bleeding off too quickly after the pump primes and shuts down. If that's what is happening, could be a faulty check valve in the fuel pump, faulty fuel pressure regulator, leaking injectors or leaking fuel lines, including those inside the tank.
Turn the key to "on" several times, rapidly. See if it starts faster after doing that.
This is exactly what it sounds like. Sounds like its not holding enough pressure.
Old Aug 12, 2011 | 07:42 PM
  #17
Red97LT1's Avatar
Should I get a 140LPH or 255LPH pump? The car is stock so I'm not sure if the 255 will make any difference.Thanks
Noenav
Mar 1, 2019 07:38 AM
jayblev95
Dec 1, 2014 06:55 AM
mspennyhughes
Nov 28, 2014 03:22 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
