Car Taking longer to start
Old Apr 24, 2005 | 08:17 PM
blaze309's Avatar
Ok i'm still battling my stumbling problem. I really thought i was getting somewhere because i used some fuel injector cleaner and some seafoam and my car ran so much better and was actaully not as annoying to drive anymore, i figured i just had dirty injectors, well i guess not because it's it started becoming more noticable and is missing just as bad as it was before now. And now when i go to start my car after it's been sitting a while it has to crank a little longer than usual what could be causing this? and could it be related to my stumbling problem? The battery is good,and just replaced fuel filter.
Old Apr 24, 2005 | 10:40 PM
Bawls's Avatar
Re: Car Taking longer to start
Check the fuel pressure. Mine was a leaking fuel rail (at the shradder valve) causing a hard start.
Old Apr 24, 2005 | 11:14 PM
CamaroSS30thAnn's Avatar
are u running rich?
if u are , could be icm/coil/optispark, how long since tune up (doubt the coil)
also could be a fuel problem , u still have the stock pump
how many miles
Old Apr 25, 2005 | 08:18 PM
blaze309's Avatar
My car has 57,XXX miles on it, we bought it from my dad's friend and he said it just got a full tune up not long ago from when we bought it, it had 52 thousand on it when i bought it. I'm going to buy a fuel pressure guage and see what i come up with.
Old Apr 25, 2005 | 08:21 PM
have u ever let the tank run low or run out , that would hurt ur pump ,
i forgot what i was gonna say maybe ill let u know later lol
Old Apr 25, 2005 | 08:32 PM
blaze309's Avatar
I've only let my tank run low once and it started bucking and everything since it was so low i guess.
Old Apr 25, 2005 | 09:06 PM
yeah def check ur pressure and c what u get , if ur pressure is fine, try to get the car to do what its doing and c what the pressure does
my problem is my pump would show a normal reading b/c it was sparatic and did it whenever
Noenav
Mar 1, 2019 07:38 AM
jayblev95
Dec 1, 2014 06:55 AM
mspennyhughes
Nov 28, 2014 03:22 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
