Car Stuttering/Missing
Old Jan 30, 2005 | 04:46 PM
SLW LT1's Avatar
When ever i give it gas 9/10 times the car stutters and somtimes makes a loud popping noise (back fire). When i get on it, it feels strong from a punch but afterward it dosent feel as strong. I am 100% postive and i losing power.
Time for new plug wires?? O ya and i do have delteq
Old Jan 30, 2005 | 05:30 PM
SLW LT1's Avatar
Re: Car Stuttering/Missing
Come on guys!!
Old Jan 30, 2005 | 05:33 PM
StickMaster's Avatar
Pop the hood when its dark out around no street lights and rev the engine, see if you see any arching. Replace as neccessary
Old Jan 30, 2005 | 05:43 PM
SLW LT1's Avatar
Arching...like sparking right?
Old Jan 30, 2005 | 05:55 PM
Yup, you can rev the engine with your fingers, by pushing the the throttle cable pully thingy to the front of the car. becareful theres all kinds of moving parts on the front of your engine, dont get a tie or a peice of your jacket caught in your belt or you can kiss something good bye
Old Jan 30, 2005 | 09:11 PM
SLW LT1's Avatar
LOL...ok thanx i will give it a try tonite!
Old Jan 30, 2005 | 10:43 PM
SLW LT1's Avatar
i did it an nothing...what else could it be
Old Jan 30, 2005 | 10:54 PM
SLW LT1's Avatar
So i replace all the wires..
Old Jan 30, 2005 | 10:56 PM
Check your grounds, I had a similar problem and it was the ground on the Drvers side Cylinder head (above where the coil is)
Old Jan 30, 2005 | 11:02 PM
SLW LT1's Avatar
Would a ground cause it to sometimes pop and back fire?
Am i able to reach the ground by hand?
Old Jan 31, 2005 | 09:07 AM
Yes. Yes. When my ground was loose, I was driving and any load and my car would buck and kick and back fire. Stopped at a gas station and figured it had to be something with the coil. I kept pushing the connector on the coil around and everytime i messed with the wires, it would stall out. So just looking around I noticed where a few grounds are on a post with a nut holding them down, the nut was loose, tighted it up by hand and the car ran fine after wards. I'd get you a pic, but the cars under snow and Im at work right now.
Old Jan 31, 2005 | 09:19 AM
1stz28's Avatar
Were you looking closely by the plugs while it was running...sometimes the arching can be kinda hidden behind the manifolds and you need to look closely. Mine were arching right from the tip of the plug wire to the base of the plug.
Old Jan 31, 2005 | 10:42 AM
SLW LT1's Avatar
I will check now and a pic would be great!! No rush tho!!
And i will rev it up again and check tonite..i was only taken it too 3000 rpm. Should i rev higher! Thanx guys!!
Old Jan 31, 2005 | 03:30 PM
SLW LT1's Avatar
I looked at the grounds and did see any lose. I might not of found them all tho
Old Jan 31, 2005 | 04:02 PM
SLW LT1's Avatar
Couldnt it also be one of my coil packs? How can i check them?
