Car stumbles/misfires when cold???
Old Aug 25, 2004 | 11:57 AM
AdamZ1LE28's Avatar
When I first start my 96Z in the morning and then after work, it will run crappy until it warms up and then its perfectly fine. You can feel it jumping from 6 to 7 to 8 cylinders randomly back and forth whenever you get on the gas at all. Its been going on for a while now and I think it started after I installed LT headers, new O2's and a x-pipe exhaust....if that has anything to do with it. Car has original opti-spark, a msd 6al ignition and msd coil.
All help appreciated thanks!
Old Aug 25, 2004 | 03:27 PM
JohnD's Avatar
Re: Car stumbles/misfires when cold???
Any time a car is hard to start or runs poorly until it is warm generally points to the coolant temp sensor. It is the one on the waterpump.
Old Aug 26, 2004 | 09:20 AM
AdamZ1LE28's Avatar
OK that makes some sense. When I changed my waterpump last year I broke that sensor but just glued it back in. I'll change that out. Is it easy? Thanks....
Britbilly
Jan 7, 2015 08:49 PM
jj71787
Dec 30, 2014 02:15 PM
cmdeshon
Dec 27, 2014 10:06 AM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
