car starts hard after longtubes and starter reinstall
I just installed my longtubes and reinstalled my starter and everything.......but when I start my car up (open longtubes) it starts way differently like it takes alot longer and it chugs a couple times then fires up nicely. Is it normal or could I have installed the starter wrong?
Re: car starts hard after longtubes and starter reinstall
If the starter where the problem, it would be cranking real slow. You would notice that I assume. The starter cranking slow would be from a current problem. Does the starter seem to be dragging? Or does it just seem to be taking longer to fire up but the starter seems to be rotating the normal speed?
Your problem with low current could be one of 3 things. Bad battery, bad wiring or bad starter. If the alternator were bad, it would simply go dead so that's not it. The easiest way to find which it is would be to monitor the voltage across the battery when you crank it over. If it drops below 11 volts, the starter is probably bad.
fpete1992
Dec 11, 2014 03:51 PM
teedoff59
Aug 8, 2002 01:36 AM
