car starts and dies..help
Had similar problem.
I had a very similar problem with my Z. It would start up fine, but would end up dying after a few seconds. The problem ended up being a torn intake elbow. Luckily, the tear was right where the elbow connects to the throttle body, so all i had to do was reposition the clamp past the tear and that fixed the problem. My car has not died after starting since this fix. Hope this helps. Good luck.
~~Wes
~~Wes
Unplug the MAF and see if it will run. It sounds like unmetered air after the MAF. Do you have A/C? If so turn it off. Another problem could be IAC. When you push the gas down does it rev normally or sputter and kick?
Ha, I love LT1's. I just went through all of that, replaced absolutely everything, had good fuel pressure, getting spark...it was the ignition switch on the back of the steering column...$27, and took me about an hour to replace, shoebox has instructions on his site. Your symptoms were mine exactly. Would not start unless you got it to fire, and held the gas down to bring the rpm's up....good luck
Originally posted by PredatorZ28
behind the dash? i installed a stereo when this started to happen, maybe i bumped it?
i am having the same problem....and am wanting to change the ignition switch....where are the instructions for this on shoeboxes site, i couldnt find it.....thanks
and oddly enuff, i noticed my power locks also, would lock by themselves, i would try and get out of the car and they would be locked??? is this related???
