Car starts and cuts off
Old May 26, 2010 | 05:45 PM
malw_95z28's Avatar
Ok. I have been having problems with the car lately. The car car will start, but takes exessive cranking to get it going. Then it will idle very rough and cut off sometimes. Then if I get it going and driving it will sputter very badly and not go anywhere. But once it shifts out of 1st gear and rolling, it drives just fine. And I won't have any problem out of it. But once at a red light I can tell it's not idleling right. But it still drives fine. Optispark has recently been replaced. As have plugs and wires. Any ideas what it may be?
Old May 27, 2010 | 05:18 AM
Guest47904's Avatar
Guest
Anyone ever looked at the fuel pressure?
Old May 27, 2010 | 08:14 AM
CstIrnFst's Avatar
That sounds like similar symptoms I had when the fuel filter was clogged. I also had the fuel system cleaned at the same time as the filter was replaced, so that may have had a little to do with it as well. Mostly the filter though, as it ran well afterwards.
Old May 27, 2010 | 09:19 AM
malw_95z28's Avatar
no i have not checked fuel pressure, i do smell gas when i start it. but i will check filter and update. thanks
97SSdude
Dec 31, 2014 07:43 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
teedoff59
Aug 8, 2002 01:36 AM
BOOGER
Jul 25, 2002 02:42 PM
