Car started this morning...now wont
Old May 11, 2008 | 01:51 PM
reamo04's Avatar
so, we were getting my car out of the garage this morning to wash it since its a nice day out, and i got my new tune, etc. for my car.
So, back it out, see a small leak from my tranny cooler....okay, no bigger.
So, get that fixed, let it sit and run and idle for 5 or so minutes since i just wrapped everything with exhaust wrap to let the impurities out. Realize that i forgot to shut my stinkin bleeder valve for my coolant (just refilled it last night). So, i had coolant sprayin everywhere....kinda pissed me off.
So, shut the car off, fixed that, and tightened a clamp that was loose on the water pump.
Now, the car wont start
It will crank, but not turn over. Its been sitting about 4 hours, and still wont start, not sure how long it takes for an opti to dry out though?
Was wondering what else your input might be.
Also, i can hear the pump priming
Old May 11, 2008 | 04:27 PM
mrmint69's Avatar
Wet opti's are bad. The time to dry out would depend on the amount that got in there and what your weather there is like. If its dry and 100 degrees it will be faster.
Old May 11, 2008 | 10:27 PM
reamo04's Avatar
well, checked the coil, coil isnt sparking.
Old May 11, 2008 | 10:28 PM
bombebomb's Avatar
I was gonna post that you should let the opti dry some more, but you already knew that. Since coil is not working id say wire, or coil, but you knew that
Old May 11, 2008 | 10:33 PM
reamo04's Avatar
yeah, i let the camaro set for 10+ hrs, and it still cranks, but doesnt fire.
So, im guessing opti is fine, but no spark.
Coil isn't sparking, think i found my culprit ( i hope)
Old May 12, 2008 | 05:16 PM
reamo04's Avatar
alright guys, got the coil tested, and ICM tested, both are good.
PCM is good.
New ignition fuse
i tried starting it, and it would sputter, and die.
I think its just a matter of letting that danged opti-crap dry out more.....
Unless anybody else has ideas?
Old May 12, 2008 | 06:54 PM
Dadic 78's Avatar
Sounds like opti... If you're a '94, you're non-vented. Keep that sucker dry!
Old May 12, 2008 | 09:34 PM
reamo04's Avatar
well, it has the MSD cap/rotor on it, which has a couple vent spots on it. I had them closed with some vacuum caps, so, i just removed them about 5 minutes ago. Hoepfully that'll help it dry out some
Old May 12, 2008 | 10:35 PM
bombebomb's Avatar
hope thats all it is
Old May 12, 2008 | 10:45 PM
reamo04's Avatar
well, just tried checking the ICM, etc.
The two outside ones are both getting 10v DC, the two inside plugs (on the harness), get nothing.
Should be the coil or fuse according to that though.....
Old May 15, 2008 | 03:45 PM
PGM95Z's Avatar
check the small harness that goes from the top of the opti to the plug up near the pass. side valve cover. one of my cars was doing the exact same thing and it turned out that the plug that goes into the opti had corroded.. replaced it and car was fine..
hth
Old May 15, 2008 | 10:34 PM
reamo04's Avatar
i checked the plugs all yesterday. Ordered a new opti today. Should be here either saturday or monday.
Old May 16, 2008 | 12:21 PM
remy2435's Avatar
my car had a similar problem and it turned out to be the maf sensor. just thought i would throw it out there, good luck.
Old May 16, 2008 | 01:38 PM
reamo04's Avatar
my car has a speed density tune, no MAF here.
I ordered a new opti yesterday, it will be here monday. I hope like hell it solves the problem, otherwise theres 400 down the drain.
Old May 16, 2008 | 02:00 PM
WS6T3RROR's Avatar
Check out your coil wire on the opti end for corrosion. You could also check out the opti harness for corrosion too.
