Car runs hotter with new headers on...
Old Jul 13, 2005 | 09:56 PM
GreenZLT1's Avatar
I put pacesetter longtubes on my car, and finally got the y-pipe and hooker catback on. I have to say, holy crap, it really woke up my car. But it seems my temp runs a bit higher than it used to. I did crack my coolant sensor while installing the headers, and put in a cheap autozone one back in. Also I deleted my AIR and EGR, and didn't have my computer tuned yet. I get no SES light because the EGR selonoid (sp) is plugged in still.. Why does it run hotter? its about 210-215 fully warm, and it used to be lower than that.
Rob
Old Jul 13, 2005 | 11:50 PM
cas0484's Avatar
Re: Car runs hotter with new headers on...
Are the headers coated? If not, they could be adding a considerable amount of heat to the engine bay that wasn't there before, that could explain your higher engine temps.
Old Jul 14, 2005 | 12:10 AM
nonojoe66's Avatar
i have the non emissions, non coated ones and mine seems to run cooler, but my car was also tuned
Old Jul 14, 2005 | 08:14 AM
GreenZLT1's Avatar
I got the coated ones. Anybody else have any ideas?
Rob
Old Jul 14, 2005 | 09:09 AM
jsetzer's Avatar
160 stat and a tune. Mine barely moves above the bottom mark.
Old Jul 14, 2005 | 09:39 AM
Bow94z's Avatar
Yup 160 Stat and Madz28 Tune does the trick you can sit in traffic for the longest time and the temp pin barely moves!
Old Jul 14, 2005 | 09:44 AM
Feenix's Avatar
Definatly can vouch for that, and I'll be seeing once the headers are on if it changes at all.
Old Jul 14, 2005 | 11:25 AM
izzyz28's Avatar
Well, you did change the sending unit, so there you go. It would be extremely hard to say just how much of the increase in temperature can be attributed to the headers and how much can be attributed to the new sensor. I'll take a wild guess and say that the actual coolant temperatrure is still almost exactly the same as it was before, so I wouldn't worry about anything.
Old Jul 14, 2005 | 01:52 PM
tfs95z28's Avatar
you could also just have the tune programmed to turn your fans on sooner. that is what i did when i got my hot cam installed, i still have the stock thermostat, but the needle barely gets above the first line and i sit in a lot of traffic here in the chicagoland area. I hear the fans turn on very early, its nice, the engine bay temps are also not too bad either, i have coated MAC mids.
ro2207
Dec 4, 2014 06:18 PM
Lederman1976
Nov 30, 2014 05:21 AM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
