car runs [poorly] when idling in traffic
Old May 11, 2005 | 02:41 PM
stephenspann27's Avatar
Once in a while.. if I sit in traffic my car will start to idle down really low, almost dying.. seems to happen more often when I run the a/c, but I have to run the a/c so that my fans are on, and my car doesnt get hot... anyways, I usually have to start reving the crap out of it, making me look like a tard... t then it finally straightens out. I'm thinking.. with my cam.. it might be picking up knock.. and when the temps gets a little higher.. the timing is retarding maybe? also.. it loses power.. where I have to slip the clutch like a 4 banger when I move up in traffic. ps. I have a high volume fuel pump.. 255lph.. maybe it's loading up?
Old May 11, 2005 | 02:53 PM
94whtZ28's Avatar
Re: car runs like @$$ when idling in traffic
what are the specs on ur cam also do you have the factory rocker arms still or did you upgrade those. Because the engine is like a big air compressor it lets air in and out.
Old May 11, 2005 | 04:33 PM
Yea I still have the factory rocker arms... the cam.. was fairly mild.. but hotter than the LT-4 hot cam.. I'm pretty sure the cam is 220/230 510/510 and the lobe seperation.. not for sure.. 115 maybe..
Old May 11, 2005 | 04:34 PM
also about the vavles.. I have to adjust them often.. had the cam about 2 years, and I've adjusted them at least three times.. they tick really bad when it's cold when they get out of adj.
Old May 11, 2005 | 10:08 PM
94whtZ28's Avatar
You might want to look into buying some Comp Cams Pro Magnum 1.6 rocker arms. It would be a very good rocker arm for that camshaft. And about you having to adjust the valves im not really sure..
Old May 12, 2005 | 12:17 AM
jdizzell's Avatar
Could be a few things....
IAC not working properly
Incoming air to hot
Vacuum leak
Tear in your elbow after the MAF
If it is worse with the A/C on I would suspect that IAC is not adjusting for the extra load.
Old May 12, 2005 | 07:10 AM
ok, I will check all that, make sure my deoterant cap is sealed off, good. ;-)
Old May 12, 2005 | 05:00 PM
BUBBA's Avatar
Re: car runs [poorly] when idling in traffic
I would guess that with that cam that your idle is going to be a bit rough anyway, especially if your pcm is not tuned for a higher idle. JMHO
Old May 26, 2005 | 05:46 PM
ayalam's Avatar
Take throttle body off clean the passages. Do A good job with q-tips and throttle body cleaner only. then take the maf apart ond clean it gently with electric parts cleaner and q-tips be careful. buy new top and lower gaskets for the throttle body.
bfmv13trivium
Jan 14, 2015 09:57 AM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
