Car is running too hot...need suggestions
Old Jul 9, 2003 | 09:17 PM
Sandman_97Z's Avatar
Car running HOT...need suggestions
About a year and a half ago I put in a 160* thermo and programmed my fans to come on sooner.
Last summer the car never got above about 200* in the middle of the day in traffic with full AC. Now that it is hot again, its getting up to around 220-230 in traffic with full AC.
Also, I have noticed that after I drive the car at temps like that, the next morning, I will see a semi-small puddle of coolant in front of the Passenger front tire. Then when I go to start the car, the low coolant light stays on. Then i can drive for a minute or two, shut the car off, and the light is gone upon restart.
I flushed my coolant with new Dex-Cool (50/50 mix) using our machine at work. I checked all my coolant hoses for cracks/leaks. I verified that my fans are working correctly. I have a new overflow bottle, and new hose from the overflow to the radiator. I have a new coolant level sensor. I do not have any oil in my coolant, or any coolant in my oil. Other then the situation above, I have no leaks.
I am sort of at a loss. Everything seems to be functioning fine.
Really the only thing I can think of is that maybe my 160*thermo is stuck open...maybe.
I could really use some help/suggestions guys!
I am starting to get at this problem
Thanks!!
Old Jul 9, 2003 | 09:22 PM
jasons93z's Avatar
Did you bleed the system? Try that, and put in some red line water wetter.
Old Jul 9, 2003 | 09:38 PM
Bled both bleeders lol
good idea with the water wetter tho
Old Jul 9, 2003 | 10:12 PM
If there is a puddle on the ground, there is a leak or it's overflowing after shut off. Rent a pressure tester to check it out. Have you replaced the radiator cap?
Old Jul 9, 2003 | 10:16 PM
pressure tested the cap...functioning perfectly
i know that it is overflowing...just dont know why i guess...
Red97LT1
9
Dec 17, 2014 06:13 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
F(ast)-body
Feb 26, 2003 09:05 AM
Desolate_Flux
Jul 23, 2002 08:24 PM
