Car running HOT!!
Old Jun 16, 2005 | 10:51 PM
LT4Z28's Avatar
Car running HOT!!
My 96 Z28 will pull up to about 250 with the AC on, driving on the highway, with 98 degree weather. Even with a 160 TStat and custom tuning, the car runs this hot. On a cooler morning, approx 75-80 degrees, the car will still pull up to about 220-235. The car has a new water pump, radiator, hoses, and a fresh LT4 kit. I have tried bleeding the system several times resulting in one little "burp". What else can I try?
Old Jun 16, 2005 | 10:55 PM
69gto96z's Avatar
Re: Car running HOT!!
Are your fans working properly?
Old Jun 17, 2005 | 03:19 PM
LT4Z28's Avatar
Fans are working properly. On first and second stage 192-off-182. Hysteresis 5 degrees.
Old Jun 17, 2005 | 03:31 PM
Gripenfelter's Avatar
Air pocket somewhere in the system.
Did you fill the water pump with water before putting the tstat on when you installed the pump? If not, thats usually a cause of air pockets.
Use the bleeder screws and make sure your overflow container has water in it.
Collector Car
Dec 17, 2014 01:12 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
