car running again... oil pressure readings?
Old 03-24-2004, 06:02 PM
96LT1TX's Avatar
My oil pressure readings seem to be way to high, could I have messed up the sensor doing a head install? when I start the car up, or even before it is at or above 80psi. even w/ key in ignition off, it is already at 80psi+. I have heard maybe i ground out the sensor by accident? Any other things that would cause this?
96LT1TX is offline
Old 03-25-2004, 04:01 PM
schpenxel's Avatar
Re: car running again... oil pressure readings?
schpenxel is offline
Old 03-25-2004, 04:05 PM
White Knight 95's Avatar
Does it fluctuate at all or is it pegged all the time? If it is pegged regardless, that would indicated that the sensor is done, I believe.
White Knight 95 is offline
Old 04-06-2004, 11:16 PM
96LT1TX's Avatar
it is always above 80psi, even w/ the car OFF. I am pretty sure that the sensor got re-grounded when I put the oil drain plug back in. any other suggestions? If my oil pressure is that high what is wrong? thanks
96LT1TX is offline
ro2207
12-04-2014 06:18 PM
jayblev95
12-01-2014 06:55 AM
BIGCOWL-IMP
11-21-2014 09:40 AM
07-04-2005 05:00 PM
Brent94Z
03-21-2002 04:44 PM
Quick Reply: car running again... oil pressure readings?
