car runing hot today any suggestions
Old Dec 28, 2003 | 04:26 PM
zuluman13's Avatar
My car seemed to be running hotter than normal today when i shut it off i saw it was above 210 i just installed my slp cai before i went out but i dont think that could be the problem is this normall or is there something i should check
Old Dec 29, 2003 | 01:39 PM
zuluman13's Avatar
ttt
Old Dec 29, 2003 | 02:28 PM
AndyB's Avatar
Your water pump could be dieing.
Old Dec 29, 2003 | 02:32 PM
95patriotZ's Avatar
Check your coolant level, if its not full, look for a leak somewhere. Get a 160* stat also.
Old Dec 29, 2003 | 02:35 PM
red 95 z28 lt1's Avatar
have you changed the coolant recentley? try bleeding the system there may be air in the coolant system.
Old Dec 29, 2003 | 02:37 PM
zuluman13's Avatar
the coolant was changed less than a year ago and i barely drive it because i only have my permit and how would i bleed the system exatcly.
Old Dec 31, 2003 | 10:38 AM
these two bleeder screws open them when the car is running if no coolant comes out, you have air in the system. wait till you see coolant comming out when you do close them and check coolant level (dont get optispark wet)
pic is on link below
http://shbox.com/1/bleeders.jpg
Old Dec 31, 2003 | 12:09 PM
zuluman13's Avatar
i did the bleeder screw thing and there was a little air but not much but when i was closing the one nearest to the intake elbow the top of the screw broke right off and i wasnt using any type of force but it just popped off luckily it was closed enough and nothing is coming out or anything but in the future I will need to replace that is that something i could do my self or would i have to go to the garage because the whole valve needs to be replaced because there is no way to get the rest of the screw out.
Old Dec 31, 2003 | 02:18 PM
you could try and do it your self (i have never done so) but i would replace the whole hose with the valve.
Noenav
Mar 1, 2019 07:38 AM
ChrisFrez
Dec 21, 2014 09:47 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
ChrisFrez
Dec 15, 2014 03:09 PM
USAirman93
Nov 24, 2014 03:37 PM
