Car refuses to idle, 1993 speed density
Old Jul 24, 2005 | 03:12 PM
onlyone07's Avatar
I've searched through many threads and found nothing that has helped me.
What the car is doing:
If I crank the car up and sit still it idles like a champ ~1000rpm on the stock tach. I know thats off, but it's just there for reference. The problem comes up when I come to a red light a few hundred feet away. I put the car in neutral and coast and the motor drops to ~400rpm then quickly jumps to ~12-1300rpm then stalls, repeatedly. Then after I come to a stop I crank the car up and it idles fine at ~1000rpm again.
What I've replaced:
IAC
TPS
O2 sensors(both)
This drives me absolutely crazy. I've replaced those sensors that I thought could be the problem and still nothing does any good. The car only does it on DECELERATION. Any help would be GREATLY appreciated.
Wade
Old Jul 24, 2005 | 03:59 PM
Jazsun's Avatar
Re: Car refuses to idle, 1993 speed density
What I've replaced:
IAC
TPS
O2 sensors(both)
Wade
Im no pro, but could be a torque converter considering it only does it in neutral.
Old Jul 24, 2005 | 04:22 PM
onlyone07's Avatar
Should've clarified I guess. It's a 6-speed with an LT4 hotcam kit, all the bolt-on's, Hooker LT's, Mufflex exhaust, etc...
Old Jul 24, 2005 | 05:06 PM
Alvin@pcmforless.com's Avatar
What I've replaced:
IAC
TPS
O2 sensors(both)
Wade
Have you had the car tuned? If not you are probally needing of a good computer chip.
Old Jul 24, 2005 | 05:18 PM
onlyone07's Avatar
Yes, it had a mail order tune from you guys I think before I got the car. Then I got it retuned by a local guy after I put nitrous on the car.
Old Jul 24, 2005 | 06:07 PM
You might want to check to see if the TB blades are open enough. Sometimes you can close hem off to keep the IAC out of a normal working range. Warm IAC counts at idle should be 20-30
Old Jul 24, 2005 | 06:20 PM
onlyone07's Avatar
I have no way of checking IAC counts.
Would the sticking TB blades only happen on deceleration? I can rev it up all day long while the car is sitting and it comes back down to normal.
Old Jul 24, 2005 | 06:25 PM
96capricemgr's Avatar
Tuned before or after the cam?
Old Jul 24, 2005 | 06:30 PM
onlyone07's Avatar
All the mods have been on the car for several years now. It was recently retuned(about 3 months ago) and I've always had an idle problem since I got the car in Nov '04.
bfmv13trivium
Jan 14, 2015 09:57 AM
Sarahrope64
Nov 27, 2014 11:17 AM
USAirman93
Nov 24, 2014 03:37 PM
Queens94z28
Nov 20, 2014 06:03 PM
Jul 4, 2005 05:00 PM
