car REAKS of gas
Old Sep 17, 2009 | 12:53 PM
TBSPW's Avatar
car REAKS of gas
my car smells so horrible of gas...if its off its almost unbearable if its running its not so bad...what could it be?
Old Sep 17, 2009 | 04:42 PM
SmokeyBlaZe's Avatar
Check your schrader valve , mine was leaking fuel until I changed the valve stem out.
Old Sep 17, 2009 | 05:04 PM
ACE1252's Avatar
Wonder if something is jacked up with the EVAP system. Something to check. I just did preventive maintenance on mine and replaced all the rubber hose connections. Every one of them crumbled in my hands when I pulled them off.
Old Sep 17, 2009 | 05:10 PM
ACE1252's Avatar
If you need to replace the hoses...see my post at the bottom of this thread for fuel and vacuum hose sizes.
https://www.camaroz28.com/forums/sho...d.php?t=697461
Old Sep 17, 2009 | 07:53 PM
bw_hunter's Avatar
Check the charcoal canister in the left rear fender. I fthat gets saturated with fuel you'll smell it like you spilled it in the car. Then check the fitting, hoses and solenoids as mentioned before...
Old Sep 18, 2009 | 05:00 AM
TBSPW's Avatar
somehow the fitting under the car by where the drivers seat is came loose...think it was the return line...thanks for the help guys.
birdblack
Dec 30, 2014 06:59 PM
blac94Z
Nov 28, 2014 01:53 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
blac94Z
Nov 24, 2014 07:12 PM
USAirman93
Nov 24, 2014 03:37 PM
