car ran fine, now stumbles badly.
Old Sep 15, 2006 | 08:31 PM
blackztpi's Avatar
car ran great. mods in sig. took iot out with some friends and it has stumbled ever since under load. it's getting worse. it does it badly from a stop sign or in the higher gears. everything ignition is new. It's almost like the opti is crap already, but the car has a new waterpump and has never seen rain. opti is 2k miles old. maybe the harness is bad or the opti is crap?
Old Sep 15, 2006 | 08:47 PM
red95ssclone's Avatar
Re: car ran fine, now stumbles badly.
was the water pump installed after the opti? water/coolant= kills opti.
Old Sep 15, 2006 | 11:39 PM
blackztpi's Avatar
no, all installed at the same time. never been exposed to anything.
Old Sep 16, 2006 | 04:22 PM
OBE1 95Z28's Avatar
Double check that all your spark plug boots are fully seated on the spark plugs and that you haven't burned any wires on the headers.
Old Sep 16, 2006 | 11:49 PM
blackztpi's Avatar
ok, i might add. This problem is not due to something stupid simple like boots being off and or burnt wires. this is the 2nd set of wires with this same problem, 3rd set of plugs. no burns in the wires or anything. what can i check to see if the opti is working??
Old Sep 17, 2006 | 06:27 PM
Fuel filter? Kind of sounds like a fuel problem now
Old Sep 17, 2006 | 09:28 PM
blackztpi's Avatar
i would assume its fine since it fixes itself when i get on it hard....also dynoed fine with the problem.
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
Queens94z28
Dec 20, 2014 09:11 PM
ro2207
Dec 4, 2014 06:18 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
