Car Overheating Only at Highway Speeds
Old Jun 14, 2005 | 04:05 PM
xfreshjiv12x's Avatar
Angry Car Overheating Only at Highway Speeds
Here is my problem. I have 160 deg thermostat, it seems at idling
or just crusing the streets is fine. but when I hit the highway and turn on my air I notice my temp gauge slowly start to climb to 200+deg. When I turn off my air while still going down the highway it slowy declines to about midway and stays there. But it stays right around 160 deg. in rush hour stop and go traffic even with the air on? Any ideas I cant seem to find any leaks anywhere.
Old Jun 14, 2005 | 04:20 PM
Alvin@pcmforless.com's Avatar
Re: Car Overheating Only at Highway Speeds
Do you still have the airdam on the car?
Old Jun 14, 2005 | 04:33 PM
RocCityZman's Avatar
Have you tried bleeding the system at all to see if there is a small bubble or something?
Old Jun 14, 2005 | 04:49 PM
birdman1's Avatar
The first summer mine was doing this, and i had the radiator rodded out, cured it for that year. the next summer it started doing it again, so I bought a new radiator. problem gone for 3 years now.
But check the easy stuff first, air dam, etc. as the others have mentioned. Also, recently mine was acting that way again, and I crawled up under the car, a large paper bag was sucked up to the radiator, blocking about a third of it, that was the easiest fix yet. "hey, I bet if I pull the trash off of my radiator my car will run cooler"
Old Jun 14, 2005 | 06:03 PM
I still have the air dam but it seems like its about to come off. Ill try bleeding the system out maybe that will work. I just got a new radiator last year.
Louey
Pacific
Dec 25, 2014 03:27 AM
Louey
Pacific
Dec 8, 2014 08:01 PM
Louey
Pacific
Dec 1, 2014 04:16 PM
Louey
Pacific
Nov 28, 2014 03:46 AM
Jul 4, 2005 05:00 PM
