Car not pulling strong at 4500-5500 RPM
Re: Car not pulling strong at 4500-5500 RPM
OK, this may sound weird but some time ago I read of a problem like this and it turned out to be the rubber bellows attached to the intake were collapsing under higher rpm and restricting airflow. The symptoms were exactly as you described. Check that out before you start replacing things.
I first noticed my problem when i got my tuned pcm. So maybe it does have something to do with the wire that runs from the pcm to the IAT or the PCM itself. Like i said my car ran fine last night with the IAT unplugged until my SES came on. I'm going to try the IAT resistor mod and see if that works.
mohawkmike,
New problem was added, it was also miss firing in low RPM (below 2000)
I went ahead and bought a fuel pressure gauge and tested pressue. Guess what, it was 20PSI under load and 30 in idle.
Changed filter, checked regulator and eventually changed the fuel pump (accel) car is back to perfect. no hesitation, no miss fire and it pulls like crazy.
Thank you all
Thank you all
owen66
Nov 30, 2014 04:21 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
